Aujourd'hui nouvelle version Alpha pour les possesseurs de la version PRO
14.0.0.0 (alpha) [17 Jan 2016]
*Important: Please re-configure the VLC player with Auto-Config in Options -> Player X. There are some important changes.
- New: PIDs Management window. This is a replacement for old PIDs Stats window that allow you do more and have full control of what EBSpro is doing with PIDs, speed, etc. It is totally written from scratch (WIP)
- New: SmartTune option added to Options -> Device (workarounds). This option it's made to avoid to retune to the same frequency if it is already set (tuned in) and working well. (turned on by default)
- SidePanel Scanner now supports change his size between blind scan list and the panel.
- SidePanel Scanner now supports the context popup menu used in BlindScan List.
- SidePanel Scanner: if you open the popup menu and you have selected a service/channel, it just stream the selected channel.
- SidePanel Scanner: DoubleClick/Enter opens the assigned action (if is a channel, play it)
- SidePanel Scanner: Some bugs has been fixed.
- SidePanel Scanner: Now you can remove selected transponder or just scan selected one (with the popup menu)
- Added support for new @vars for players (sid, srvname, srvprov, pmt_pid, tid).
- Improved Auto-Config for VLC (now also detects the 64 bits version of VLC). IMPORTANT! Please re-configure yours with the new changes.
- The popup menu behavior of Blind Scan list has been rewritten to be more snappy and smart (WIP).
- Added preBER support in Signal Analyzer (you need a compatible device and 'refresh transponder info' turned on)
- Changed preBER/BER bars behavior.
- Clicking in preBER/BER bar now you can switch between pro/normal measurement mode.
- Fix: Deleting all ranges/selected ranges makes the 'Add' button to be disabled.
- Fix: Recording warning should also work on main window. Some improvements here too.
- Fixed uptime problem if the signal is locked out of SA.
- Improved internal device handling.
- Some important internal improvements.
- Bug fixes.
- Remove: PIDs Stats window (use now PID Management instead PIDs Stats)
- Updated: StreamReader.dll 1.2.3.1334.
TSA specific (v1.6.0.0):
- Some small changes & fixes.
