Alitronika & TSReader
Posté : mer. 23 mars 2016, 18:12
Hello, I trying to use an Alitronika AT40USB ASI to USB device with TSReader Pro 2.8.46b. It seems to work, TSReader recognizes it, but I have a little issue that I'm not able to solve. Sending ASI stream to input port, opening TSReader, it does not show transponder contents, but device is recognized. So, I must open its own application DVStation 4, click on Monitor button, close the application, open TSReader again and this time, as soon as launched, TSReader shows immediately all PIDs correctly. So, the problem does not seem TSReader. Once powered on, it seems something is "closed" in Alitronika device, and just its own application can "open" right way. Any idea how to obtain same result just with TSReader without opening the other applications at first? Thanks.
