12.4.0.1 (beta) [5 feb 2015]
- Added an option to the popup menu to "Delete All" in scan ranges.
- Added some missing menu icons.
- BLScan: "Alpha" and "Beta" methods should be a bit more accurate now under some scenarios.
- Fixed a bug that shows an error message if you're recording a full stream TS to harddisk and then you try to scan TS (TSA's SA).
The message just should appear if some kind of TS filtering is happening in the background.
- Workaround to wake up a network device before start the TS dump (just applied for network drives)
- Changed "True" to "OK" and "False" to "ERR" in satfeeds status.
- Numeric box in BS Mode for frequency should go up/down 0.100 MHz/click and not 100 MHz.
- AllSats.txt list updated (thanks to @PantaSat)
- Some small bugs has been fixed.
