NS3 / NS4
Re: NS3 / NS4
Anyone found any NS3/NS4 frequency for Roland Garros feeds? Just checked but found nothing at 10E, as I said I have problem to lock Hytpermux at 7E yet (I had no time to better adjust my dish). But I don't believe they use all Hypermux for 10 Roland Garros courts..... maybe a specific transponder could be used. Any update is greatly appreciated. Thank you.
Re: NS3 / NS4
New symbol rate at 7 East, 11158 GHz horizontal polarity. New SR would be 70.000. Signal seems a little bit weaker here in North Italy. Any other report? Thanks.
Re: NS3 / NS4
Most of the EBU Hypermux have switched to NS4 (instead of NS3 enhanced) with new SR worldwide on the 6th of June
Re: NS3 / NS4
On voit que EBU ne les paie vraiment pas cher ces IRD....Feedsat a écrit :Most of the EBU Hypermux have switched to NS4 (instead of NS3 enhanced) with new SR worldwide on the 6th of June
Re: NS3 / NS4
Hello guys,
Can anyone see the content of the ns4 transponders located at 3w and 7e?
Best regards,
Liviu
Best regards,
Liviu
Re: NS3 / NS4
[quote="liviu650"] Hello guys,
Best regards,
Liviu [/quote]
What is the problem?
Best regards,
Liviu [/quote]
Re: NS3 / NS4
hi, have you ns4 ird ?liviu650 a écrit :Hello guys,
Best regards,
Liviu
Re: NS3 / NS4
The problem is that i get a lock on those transponders, bunt cant see their content. I can see the content of the NS3 transponder on 10 E. My sw version is NS2000.6.1.0.3111.Feedman a écrit :What is the problem?liviu650 a écrit : Hello guys,
Best regards,
Liviu
Best,
Liviu
Re: NS3 / NS4
have you high bitrate option on your ird ?liviu650 a écrit :The problem is that i get a lock on those transponders, bunt cant see their content. I can see the content of the NS3 transponder on 10 E. My sw version is NS2000.6.1.0.3111.Feedman a écrit :What is the problem?liviu650 a écrit : Hello guys,
Best regards,
Liviu
Best,
Liviu
Re: NS3 / NS4
I dont'n know what option is that. When is locked the transponder has 198.40Mbps.
Best,
Liviu
Best,
Liviu
Modifié en dernier par liviu650 le mar. 01 août 2017, 19:47, modifié 1 fois.
Re: NS3 / NS4
Re: NS3 / NS4
Il y a une hotline ddédiée si vous avez des problemes pour les Feeds de l'UEFA (tel masqués)
Hypermux NS4 ,3°W, testcard permanente
Re: NS3 / NS4
I heard EBU introduced some DRM on radio frequency carrier. If so, no lock on all non-authorized IRDs. Have you any additional information please? Thanks.
