comment ? sans trahir de secrets : avec ce qu'il faut !Tony45 a écrit :Putain feedsat, comment, Comment, COMMENT ? XD![]()
Est ce que tu serais partant pour faire un petit teamviewer un jour ? Tu habites dans quel coin ?
NS3 / NS4
Re: NS3
Re: NS3
Clair.mattmatt73 a écrit :comment ? sans trahir de secrets : avec ce qu'il faut !Tony45 a écrit :Putain feedsat, comment, Comment, COMMENT ? XD![]()
Re: NS3
Yes for 10°E and 3°W (at the moment)Feedman a écrit :Thank you Feedsat for your reply. I know that specific demodulator is needed for that signal, but which dish size? At 10 East this signal seems not so strong.... Also, these Hypermuxes broadcast always the same services (one is perfect copy of the other)? Thanks.
The signal is good on both satellite but with these parameters the EBU prerequisite are (for 10°E):
According to my little experience, even with a good signal, if the link margin is too short, you can't get the whole content of the package.
No, the content change for the live event, but NBA, ESPN, etc are always active.
Example of the stream content, right now:
Re: NS3
Merci Tony45Tony45 a écrit :Putain feedsat, comment, Comment, COMMENT ? XD![]()
Il m'est hélas impossible de souscrire à ta requete, restons modeste, ce n'est que de l'amusement.
tu as l'air très enthousiaste sur le sujet
Re: NS3
OK, encore une capture pour la route de ce mux, en ce moment.
le contenu change tres souvent, en fonction des matchs, etc.
Petit tour par la Dektec
Re: NS3
OK Feedsat, I understand link margin problem. I believe (not sure) this signal is not only in NS3 but 16APSK modulated, too. So link margin is very important. Based on your experience, which dish size is required to lock the signal at 10E? Thanks.
Re: NS3
From the Netherlands, same dish size as France,1.80m is probably good enough even during bad weather conditions . (You are in Netherlands, Am I right ? )
Re: NS3
OK, same antenna size for Milano according to the EBU prerequisite...
Re: NS3
Je constate (par hasard) qu'il y a un 2ieme MODCODE dans les TX de l'UER, en BPSK 1/5
"DATA in high resilience", renseignements pris.
Juste pour info.
Exemple:
Juste pour info.
Exemple:
Re: NS3
Ben bpsk en 1/5 c'est sur que l'on est dans le high résilience !Feedsat a écrit :Je constate (par hasard) qu'il y a un 2ieme MODCODE dans les TX de l'UER, en BPSK 1/5
Juste pour info.
Exemple:
