Nous sommes le lun. 24 sept. 2018, 10:31
CrazyScan
CrazyScan
Message par Feedsat » jeu. 27 févr. 2014, 12:09
Fil dédié au logiciel CrazyScan
Re: CrazyScan
Message par lolo59 » jeu. 01 mai 2014, 19:47
tempo a écrit :StreamReaderEx-BDA 1.1.0.1172-mod
  • Fixed BDA filter connection in some cases.
  • Fixed bitrate calculation for cable/terresrial devices.
  • Fixed TS bus config for TeVii DS300x-based devices.
  • Support for second-generation DS3103-based TeVii devices (S662, S482). Require driver 5.1.8.5+.
  • Minor fixes for LNB power control IC (LNBP21, LNBH23/24, IS6422/23).
CrazyScan 1.0.1.99 (beta)
  • Save transponder info in various format.
Re: CrazyScan
Message par Feedsat » mar. 09 déc. 2014, 14:12
Suite mise a jour, petit correctif du streeamreader pour les utilisateurs de la 6983
Info de Crazycat:
StreamReaderEx-BDA 1.2.2.1251 (Beta)
http://crazycat69.narod.ru/sattelite/St ... Ex-BDA.rar
* changed default TS bus mode for TBS 6983 (prev version have some problem with streaming zombibud multistream @ 5E)
Rappel de la mise à jour en cours:
StreamReaderEx-BDA 1.2.2.1248 (Beta)
* Full TBS 6983 support with direct hw control STV6120/STV0910ADB
* Ultra-fast and accurate BLScan2() implementation for STV910. Hardware-accelerated edge detection + find unlockable transponders (with poor snr and negative link margin).
* New function ModInv() - detection available frame modcodes for DVB-S2 transponders. Implemented only for STV091x (now only TBS 6983)
* Rewriten CXD2820R support. Extended SingnalInfo2 with specific DVB-T2 params.
For 6983 possible force single mode and double LDPC FEC performance (DemodMode=1 in streamreader.ini). STV6120 is wide-band tuner, so possible extend IF range to 250-2150MHz (IFStart, IFStop in streamreader.ini).
With current 6983 drivers better always use Tuner A, because using B cause driver lockup after close !!!
CrazyScan 1.0.2.112 (Beta)
http://crazycat69.narod.ru/sattelite/St ... zyScan.rar
* Modcode selection simplified,
* Read available frame modcodes for DVB-S2 transponders in Carrier search dialog (if ModInv() supported)
* Mark unlockable transponders and ACM/VCM.
* User-defined freq ranges selection in Range tab. Predefined ranges defined in ranges.txt file.
* Move some style-specific checkboxes to Style tab.
* Save BLScan2 checkbox state in settings.
http://crazycat69.narod.ru/sattelite/St ... CS-New.png
BLScan, BLScan2 1.2.0.1247
http://crazycat69.narod.ru/sattelite/St ... BLScan.rar
http://crazycat69.narod.ru/sattelite/St ... LScan2.rar
* Show in report unlockable transponders.
Re: CrazyScan
Message par Feedsat » sam. 13 déc. 2014, 22:15
CrazyCat:
StreamReaderEx-BDA 1.2.2.1254 (Beta)
* Speed-up RFScan() for STV6120 tuner chip (TBS 6983)
* Minor fix in carrier search algo for STV091x.
* Initial support for TBS 6908 (2x stv6120+stv0910adb + FPGA-based PCI-E bridge).
CrazyScan 1.0.2.115 (Beta)
* Modcodes now can be detected on request after success carries lock for DVB-S2 (Detect button and time selection activated).
* Increased maximal items num in Predefined ranges combobox.
Re: CrazyScan
Message par Feedsat » mer. 17 déc. 2014, 22:43
Crazycat:
StreamReaderEx-BDA 1.2.2.1257 (Beta)
* Adaptive TS FIFO sync control for STV091x (must resolve problem with reception/scanning ACM/VCM transponders in previsious build)
* Improved BBFrame filtering engine (TBS 6925/6926/6983).
Re: CrazyScan
Message par stephan94 » sam. 20 déc. 2014, 10:35
avec les derniéres nouveautés qui sont maintenant á disposition on a fait je pense un bon en avant assez considérable pour le réception des fréquence difficiles
avec la nouvelle version de Crazyscan 1.02.115 aidé de la carte TBS6983 on obtient de trés bons résultats.
Ici un exemple sur le satellite Intelsat 904 60° Est franchement difficile à recevoir.
Certaines fréquences ne sont pas accrochées mais elles sont maintenant indiquées , bref super progrès.
Re: CrazyScan
Message par lolo59 » sam. 20 déc. 2014, 10:49
Bonjour stephan94 tu pourrais faire une comparaison dans la meme configuration avec la TBS 5925
Re: CrazyScan
Message par stephan94 » dim. 21 déc. 2014, 11:15
Bonjour Lolo59
Cette configuration ne fonctionne pas franchement avec la 5925 car celle-ci ne supporte que partiellement le BLScan2
bon Dimanche
Re: CrazyScan
Message par lolo59 » dim. 21 déc. 2014, 11:31
Ok stephan94 merci pour ta réponse :wink:
Re: CrazyScan
Message par Feedsat » jeu. 25 déc. 2014, 10:27
Nos en sommes maintenant à la veresion: 1.02.118
