UHD
Re: UHD
Re: UHD
Re: UHD
Il n'a pas changé depuis un an et il est rappelé 3 messages plus haut dans un tableau que je prends la peine de faire et mettre a jour.
La frequence est repris sur la totalité des sites de màj des frequences.
Tu poses la question dans quel but, par ce que tu ne sais vraiment pas ?
Pour parametrer ton smartjoy ?
Re: UHD
le smartjoy est UHD ? ou il a une sortie IP pour streamer sur un pc ,Feedsat a écrit :Il n'a pas changé depuis un an et il est rappelé 3 messages plus haut dans un tableau que je prends la peine de faire et mettre a jour.
Re: UHD
Sky Deutschland to show Ultra HD live concert
broadcaster Sky Deutschland will transmit a concert by German hip-hop band Die Fantastischen Vier live from Stuttgart in Ultra HD (4K) resolution on December 20, 2014.
The transmission is part of a comprehensive media partnership Sky Deutschland signed with the band and its record label Sony Music. According to the broadcaster, it will be the first live coverage of a concert in Germany in the Ultra HD format which offers a resolution four times higher than the current HDTV standard.
The concert will be distributed as a test run to four selected households and probably to two multiplex cinemas in Berlin and Munich.
Sky Deutschland will also offer the concert as an HD live event to its subscribers on pay-per-view service Sky Select. All Sky sports bars will also have the opportunity to show the concert live in HD.
Re: UHD
Plus proche de nous:
SES and Samsung telecast Linkin Park concert in Ultra HD
logo Satellite operator SES (Astra) , in cooperation with Samsung Electronics Co. Ltd, today announced that it will broadcast live the American rock band Linkin Park Ultra HD over European ASTRA's orbital position at 19.2 degrees East. concert Linkin Park on 19 November 2014 from the O2 World Berlin will be the world's first live concert broadcast via satellite and encoded in HEVC standard resolution of 3840x2160 pixels, 50 frames per second with a color depth of 10 bits. Transmission of the concert will be exclusively distributed on Astra Ultra HD demo channel. Direct transfer begins at 21:00 CET and can be received with television receivers Samsung Ultra HD 2014. SES Platform Services, a subsidiary of SES, will handle the encoding of content.
Astra 1L : 10994 H 22000 9/10
Pour résumé Français: Concert de Linkin Park en UHD sur Astra le 19/11 depuis l'O2 de berlin à partir de 21H00.
Re: UHD
Re: UHD
Feedsat a écrit :Plus proche de nous:
De mon coté ce sera juste en HD pour ma résolution d'image
Re: UHD
Re: UHD
Pour ma part j'ai l'image mais pas de son, faut dire que j'ai pas trop cherché non plus
Re: UHD
Par contre un truc étonnant :
Certains videos players qui ne peuvent lirent l'image (SMPlayer,lecteur windows media), eux me sortent un son , et ceux qui ont l'image ne me sortent pas de son???
ah que la technique est difficile, surtout le soir.
Re: UHD
à Ryle :
- avec mpc-hc (Lav 0.63) j'ai l'image ET le son "presque" sans saccades après upgrade à i7 4790 à 98% de charge- (en attendant une carte graphique plus puissante avec display port)
- avec VLC pas d'image mais le son est impeccable...à défaut de se rincer l'oeil on pourra toujours se décrasser les tympans avec ce groupe, ce soir !
SAUF : si la mire de la SES (sans audio) ne disparait pas au bon moment...
Elle est diffusée depuis ce matin sur ce TP 10994 H 22000 à 19e...(RAS sur HB 4K test)
Quequ'un pour confirmer svp ?
Merci.
à Ryle :
Merci.
