Bonjour à tous
Je vends un récepteur Technomate TM-1000 D neuf dans son emballage
d'origine pour 80E
Il possède la fonction Blind Scan pour les amateurs de feeds!
Ainsi que de très nombreuses fonctions:
Caractéristiques Principales :
- Numérique : Oui
- Analogique : Non
- Nombres de Canaux : 5000
- Nombres de Lecteurs : 0
- Contrôle d'accès : Aucun
- Nombres de PCMCIA : 0
- Moteur Compatible : Diseqc 1.2
- Bouquets compatible : Chaînes gratuite uniquement
One of the fastest receiver ever
280mm x 55mm x 235mm
Blind Search {power scan }
1 CI (Common Interface)
Less than 1 Second channel change
Up to 70 Satellites and 5,000 channels
65mbit sd ram total memory
Fully DVB compliant
DiSEqC Indicator
Multi-Event Timer
Full navigation auto finding and auto tuning
Full navigation blind search auto finding and auto tuning
Super Sensitive tuner for very weak signals
On Screen diseqc and usals positioner display- moves dish incase of rain and bad wheather
Auto satellite finder- just turn usals ON and select, for example, HotBird and it will find it instantly
High quality video and sound by MPEG-2 standard
Easy-to-use menu system with comments for guide
Channel deleting, moving and sorting functions
Automatic digital Satellite signal detecting Function
Separate automatic search for newly added transponders and channels
Multiple switch types, LNB types and NTSC/PAL Monitor types
Manual editing function of Transponder Information
Support PAL/NTSC system
Parent control function
Last channel auto-saving and recall function
Satellite name-change function
Hi-speed software upgrade through RS-232(NULL Modem)
Receiver-to-receiver data transfer via RS232
PLL type RF-Modulator (Ch. 21- 69) and UHF tuning function
Favourite Channel function
Antenna-positioning-help function
Timer Function
Teletext Function
Automatic FEC and PID detection and manual entry of PID value
Pause function
Loop through tuner and satellite
Real Time Clock
Multi-Language OSD
Delete Function subtitle supported by osd & vbi
8 Favourite Channel grouping and sorting function
						 Un forum détente et hors-sujets.
