I think there is a misundurstanding. I do understand that there are non-penetrating mounts whitch are available on the market. I will certainly buy one. But your advice was to buy also LNBs with small heads (23mm). So my question was : where can i find non-standard LNB supports thats feeds 23 mm LNB? I have seen in the photo you share that your LNBs support isn't the one given with the wavefrontier. Where did you find it? How can a mesure the right position for the LNB in the non-standard support?
I apologize for my poor English.
No, apologies for me not speaking French (however also English is not native tongue).
When I bought my 23mm LNBs they came with adapters to be fit in 40mm clamps.
So, you just put adapter in the original clamp and then LNB inside it, that is all.
https://www.dropbox.com/s/x0bzbw2runy0h ... 9.jpg?dl=0
Thanks. if i gan get And to get 2 satellites with 2° separation with th original LNB support that's great.
Between 17*E and 19,2*E is more than 2*, so should not be a problem to get both satellites by using original holders. Moreover, you make maximum signal on weaker satellite (assuming that is 17*E) and then just attach LNB for 19,2*E, it has very strong signal and even if LNB is not in focus you will get good signal anyway.
Ca se reçoit en Europe avec des antennes classiques le amos à 17E ?Sona a écrit :Thank you it's perfect.
mattmatt73 a écrit :Ca se reçoit en Europe avec des antennes classiques le amos à 17E ?Sona a écrit :Thank you it's perfect.
Non
donc avec une T90, on doit avoir entre rien et pas grand chose....Feedsat a écrit :mattmatt73 a écrit :Ca se reçoit en Europe avec des antennes classiques le amos à 17E ?Sona a écrit :Thank you it's perfect.
Non
Ah bon? Mon moral est au plus bas. Il y a une seule chaine qui m'interressait sur ce satellite et il n'est que dessus. Tanpis pour moi et merci.mattmatt73 a écrit :donc avec une T90, on doit avoir entre rien et pas grand chose....Feedsat a écrit :mattmatt73 a écrit :
Non
Merci pour ce billet. Le truc c'est que les photos ne sont plus visible ce qui m'a fait galéré (la photo pour le réglage d'élévation m'aurai été utile). En fait j'ai remplacé une parabole orienté sur Astra 19.2E. Je n'avait pas d'outils pour régler l’élévation et j'ai donc essayé à l’œil par rapport à l'ancienne. Grave erreur!!! Après plusieurs heures de réglages inefficace j'ai fabriqué avec une feuille de papier et un rapporteur un angle de 38° et en posant le niveau dessus, j'ai pu régler l’élévation et ainsi retrouver Astra 19.2E en mono-satellite en position centrale. Visuellement l’assiette est beaucoup plus verticale que l'ancienne ce pourquoi je n'arrivait a la régler. Bon ceci étant fait je décide de m'attaqué au multi-satellite. Je vais donc sur le site de satlex et entre les satellites d'extrmité Eutelsat 21B (21.5° E) et Eutelsat 12 West A (12.5° O). Par rapport à ma position on me calcule un Satellite imaginaire du milieu: 4.5° E. Je fixe donc ma lnb1 en 0 sur le rail et règle la parabole Angle d'inclinaison (skew) WaveFrontier: 90.78°.Je pointe le sat le plus proche du satellite imaginaire donc sur Astra 4A (4.8° E) avec 84%. Bon ça fait donc 0.3° d'écart puis j'essaie donc de régler ma lnb2 sur Astra 1KR/L/M/N (19.2° E) et regalère en fait astra 19.2 doit se trouver vers -17.8 et finalement je vous passe les détails mais j'arrive à le trouver vers -11. Alors j'ai 0.3° d'écart par rapport au sat imaginaire mais ça n'explique pas la différence de presque 7° sur le rail. Mon problème c'est que je n'arrive pas à pointer d'autres satellites alors que j'ai bien astra 4.8 en 0 et astra 19.2 en -11. Je me dis que si j'arrive à avoir ces deux là je devrai pouvoir avoir les autres mais non donc j'ai besoin de votre aide. Merci d'avance
(Léglise)
As tu reglé la déclinaison de la toroidale?
As-tu bien effectué tous tes réglages de bases ?
1) Elevation (regarde bien sur le schéma où mesurer l'angle).
2) Skew
3) Azimut
2) Skew
3) Azimut
Merci pour vos réponses. Super les schémas c'est ce qu'il manquait au forum. Bon j'ai bien réglé l'angle scale puisque j'ai pointé astra 4.8E en sat central. J'ai réussi aussi a régler ma lnb2 sur astra19.2E. Le problème c'est que satlex me le positionne en -17.8 et moi je le pointe en -11. Donc je me dis que si je pointe deux sat différents en même avec 14.4° d'écart c'est que tout est bien réglé (a moins que je me trompe). En plus l'élévation des deux sats est différente 39.74° pour le premier et 37.32° pour le deuxième. Donc le skew doit être bien réglé. J'arrive a afficher des chaines de astra 4.8 et de astra 19.2 donc ces deux lnb sont bien reglées. Le problème est quand j'assaie de pointer un autre sat Eutelsat 21B (21.5° E) ou Eutelsat 12 West A (12.5° O), je glisse la lnb sur toute la longueure du rail des deux cotés et rien pas de signal. J'envisage d'essayer de pointe rEutelsat 21B (21.5° E) ou Eutelsat 12 West A (12.5° O) en sat central pour voir si j'arrive a capter ces satelitte avec mes lnb. Ca vient peut-etre de ces lnb. Merci de votre aide.
Wavefrontier
elevation 39,7
deviation 0,0
skew 90,8
LNB satellite pos WF cm last
1 - D Eutelsat II f3 21,5 -20,5 0,0
Astra 1 19,2 -17,8 0,0
middle 4,5 178,54 39,69 1,005 0,0
1 - A Hot Bird 13,0 -10,4 0,0
1 - C Atlantic Bird 1 -12,5 20,6 0,0
Voila les 4 satellites que je veux pointer et à la place du middle, j'ai pointé en position 0 sur le rail sur Sirius 4,9. par contre astra1 se trouve vers -11 au lieu de se trouver vers -17.8.
elevation 39,7
deviation 0,0
skew 90,8
