EBS Pro
Re: EBS Pro
Nouvelle version beta de EBSPro
pas encore essayé , vient d'arriver
les changements
11.1.0.0 (beta) [25 aug 2014]
- Added an input dialog asking for a description when you add a tp from the SA's window.
- Added an option to Hide or halt motor in the wait popup window (just move the mouse over the control and the options will appear)
- Rewritten the LNB handling code and added support for more LNB types.
- Added support to check input LNB params.
- Read the IFStart, IFStop, LNBMid and LNBStk values from StreamReader.ini and handle it with the LNB handling rewrite.
- GotoX calculation issue resolved (this could improve the USALS precision)
- Set focus always to the Scanner tab when you switch to other main tab and then go back to BlindScan tab.
- Fixed a possible instability issue caused by the Signal Analyzer window.
- Now checks if profile name already exists before overwrite it.
- Now shows popup advise when you try to modified the step size in BLScan2 mode.
- Show in RF Scanner could crash with ultra low SR transponders.
- Update the data base structure just when new version of the main app is detected (This can speed up the start time a bit)
- Improved the report information (output) by item (added the BS mode used, the elapsed scan time and improved the datetime format)
- Added 'elpased time' support for DT mode in SA's Window.
- Some fixes in BLScan2 mode and DT.
- Fixed a problem with Favorites that can cause a null value.
- Internal crash when switching from a C-Band profile to a Ku-Band profile (and viceversa).
- Fixed an issue with WindowsXP and the URL encode function.
- MaxSR scope fixed for SA's window (60000 ks).
- Forced DiSEqC macro if diseqc 1.0 is configured and Diseqc mode is set to auto. This should fix some MultiSW Setup issues.
- StreamReader library updated to version 1.2.0.1207.
- Small DB fixes.
- Small fixes.
SmartUpdater:
- Small bugs has been fixed.
bon essais
les changements
- Small DB fixes.
- Small fixes.
SmartUpdater:
bon essais
Re: EBS Pro
Nouvelle version aujourd'hui
avec d'après ce que je vois quelques modifications vis à vis du LNB
11.1.0.1 (beta) [31 aug 2014]
- Fixed random crash while doing a blind scan with individual frequencies.
- Some fixes if the list of the devices is empty.
- Some important bugs has been fixed regarding the new LNB handling rewrite (need more test)
- Improved the detection of the custom LNB profiles and automatically set the 22khz tone if the LOFSW is defined.
- Important fixes with the support to store/restore pls_mode/code in the favorite list. New copied transponders should have pls_mode = 3 (off) by default.
- GotoX; math function that gets the low nibble of the last byte is sometimes an invalid value. Now uses a table instead.
- If the device does not support SignalInfo(), the motor driving speed is always handled with the maximum speed (18v). Added a workaround to fix it.
- Some improvements with the information reported to EBSpro Mobile.
- EBSpro Mobile sometimes can avoid the channel tuning when is requested. Fixed.
- A few important fixes regarding to the signal parameters shown in SA window.
bonne soirée et bons essais
Re: EBS Pro
11.2.0.0 disponble
Re: EBS Pro
L'as-tu essayé en bande C ?
De mon côté, depuis l'apparition du menu qui permet un scan sur une bande réduite de fréquence, c'est inutilisable en bande C. Le menu affiche des fréquences Ku alors que tout est configuré en bande C. Le RF scan ne fonctionne plus du tout non plus.
J'ai tout essayé sans succès.
Du coup j'ai plusieurs versions de retard.
Re: EBS Pro
Houla, tu as raison, ça marchait encore pour moi hier avec l'avant derniere mouture 11.1.0.4 de memoire mais là c'est pas la peine, je vais en parler à cjcr, vu q'il n'a pas de bande C, il n'a pas pu s'en rendre compte.
Il n'y a plus de fond, l'analyseur est placé n'importe ou, le range c'est du grand n'importe quoi.etc
encore mieux ...
encore mieux ...
Re: EBS Pro
Oui, pour avoir discuté plusieurs fois avec cjcr, il n'est effectivement pas équipé bande C.
Certes, j'aurais dû le contacter puisque ça fait plusieurs versions que le problème est présent.
Mea culpa.
Mea culpa.
Re: EBS Pro
Pour ma part cela fonctionnait bien mais plus avec la 11.2.0.0, heureusement que j'ai les autres versions .
Merci de m'avoir alerté
Re: EBS Pro
Moi aussi j'avais conservé quelques fichiers d'anciennes installs qui m'ont permis de redescendre à une version 100% fonctionnelle.
Tu peux d'ailleurs dire à cjcr que si il a besoin de tests, de logs, je suis dispo (j'ai déjà fait ça avec lui).
Par contre, dis-le moi juste en MP avant, il me connait sous un autre pseudo.
Re: EBS Pro
Actuellement 22:30h la version n'est plus disponible au téléchargement.
vraisemblablement retirée du à ces différentes remarques.
Re: EBS Pro
Oui, il vient d'indiquer qu'il s'agit d'un problème lors de changement de profil, qu'il peut reproduire le phénomène et retire la 11.2 pour le moment
Re: EBS Pro
après la version un peu ratée du 5/09/14 ( surtout au niveau bande C )
en voila une nouvelle ( avec le temps qu'il fait en plus)
11.2.0.1 (beta) [08 sep 2014]
- Added an optional weather report in the Signal Analyzer's status bar (powered by openweathermap.org API) - turned off by default.
- Added Tools' menu to the main window to faster access to common features.
- Improved the LNB management behavior.
- Save as XML doesn't work. Fixed.
- Improved choose data folder and the 'set default' option.
- Restart signal stats before SetChannel/BLScan().
- Fixed an important bug regarding the LNB management when changing profiles (?)
- Crazy Sat
Re: EBS Pro
EBSpro 11.2 has been released (updated)
posted on September 11, 2014 by admin | Leave your thoughts
Yeah, we skipped the 11.1 version, why? v11.2 sounds better than v11.1.0.2.
Highlights
Rewritten LNB handling code (now supports more lnb types, better compatibility and much more).
Weather report in Signal Analyzer.
Tools’ menu to the main window to faster access to common features.
USALS code improved.
DiSEqC fixes here and there
Better support for BLScan2() devices
Initial support for the new TBS6983 (for now just in BLScan2 mode)
Lots of bugs have been fixed (around 20 major and minor bugs)
Blindscan et RF scan sur le C-band 5°W.
http://www.igreklik.com/slike/images/67 ... 475706.jpg
http://www.igreklik.com/slike/images/19 ... 524872.jpg
Highlights
Re: EBS Pro
En 11.2.0.2 je viens de me rendre compte qu'en mode direct tuning, la frequence affichée est la valeur IF, ce n'est pas jun gros probleme en soit mais anormal tout de même.
