Euroradio
Feedman
Euroradio
Message par Feedman »
Hello, I'm looking for information about european radio feeds by EBU. This service is called Euroradio. Some years ago they were at 7 East (like TV feeds) but they used a proprietary non-DVB transmission technology. What about actual situation? Probably they switched to IP (it would be surely more simple for an audio-only service), but I have no updated news. Also, I receive a fixed carrier at 7 East, 11040H, SR 1905. Strong signal but I was never able to lock. Is this related to Euroradio? Thank you for your infos.
Re: Euroradio
11040 H 1905 is a DATA GS stream (MIS) not a radio channel.
There are plenty of low sr at 7°E but most of them are data.
11024 & 11025 V 365 3/4 are Radio feed (not always ) but I don' tknow if it's euroradio.
good luck.
Re: Euroradio
Feedsat a écrit :11040 H 1905 is a DATA GS stream (MIS) not a radio channel.
good luck.
euroradio is not on satellite, they use landed line. IP and ISDN line
Feedman
Re: Euroradio
Thank you for infos. So, as I suspected, no satellite. Feedsat, what equipment you use to lock extremely low symbol rates? I tried with TBS5925 and EBS Pro, but I reached no less than 700-800K, never reached 300.
